Turboflash
- Mar 18, 2019
- Southern MN
X2. Balance/harmonics/resonance is very important. Historically, many engines, clutches, shafts, flywheels, exhaust pipes, engine mounts, bulkheads, etc, etc have failed due to getting it wrong.
Fords4life
- Dec 7, 2021
- South Dakota
Was talking with service manager yesterday at my cat/yamy dealership, he came from textron as a enginear, worked on thundercat development, asked why the bushings in the upper chaincase gear wont last for some, including me, he stated harmonics and vibes.X2. Balance/harmonics/resonance is very important. Historically, many engines, clutches, shafts, flywheels, exhaust pipes, engine mounts, bulkheads, etc, etc have failed due to getting it wrong.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Maybe he won't admit its a bad design and cheap bushing.Was talking with service manager yesterday at my cat/yamy dealership, he came from textron as a enginear, worked on thundercat development, asked why the bushings in the upper chaincase gear wont last for some, including me, he stated harmonics and vibes.
Fords4life
- Dec 7, 2021
- South Dakota
Main reason he left textron, did not like the direction they were headed.Maybe he won't admit its a bad design and cheap bushing.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
From what my dealer tells me, most upper bearing wear comes from overtight chains serviced by customers. My sled has been boosted since day one. It hooks hard and is ridden hard. I pulled the gear while servicing the chain case and found little if any wear as compared to a new bushing. Since the bushing is inexpensive a new one was pressed in. Would have had no problem running the old bushing for many miles.Maybe he won't admit its a bad design and cheap bushing.
No doubt the lower bushing behind the brake is an issue. They change lots of them on all the cat models. 6000's, 7000,s, 8000,s, and Turbos.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The upper gear bushings are junk.
We have seen quite a few of them shot with proper tension on the drive chain.
The dealer is telling you a story.
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
21 uppers worse you guys see? I never had an issue but ran 25 uppers and not oem.
I haven't seen a stock bushing make it past 3000 miles, unless the sled has a driver that just puts along.
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
I guess the Taylor gears are that much better?
Don’t run oem
Have seen them with over 15k miles
Don’t run oem
Yes, and probably a better bushing.I guess the Taylor gears are that much better?
Don’t run oem
I got some bushings from NYturbo with an improved metal content, and they last much better.
I run the Scott Taylor gears as well. I think on top of the forged gears the fact that both the top and bottom gears are both 15wide contribute to their longevity.I guess the Taylor gears are that much better?
Don’t run oem
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
Maybe I am just lucky with my bushing. Got 5000 miles on mine and it was still more than serviceable. I run a mod stock turbo, about 300hp, heavily studded, TAPP clutch, and drive it like I stole it much of the time.I haven't seen a stock bushing make it past 3000 miles, unless the sled has a driver that just puts along.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
So your running a 22 thundercat.
Jarrett mentioned they changed something for 22 model year.
Hopefully we will hear more from the 22 model year sleds.
Maybe they have in fact used a better bushing!Maybe I am just lucky with my bushing. Got 5000 miles on mine and it was still more than serviceable. I run a mod stock turbo, about 300hp, heavily studded, TAPP clutch, and drive it like I stole it much of the time.
Fords4life
- Dec 7, 2021
- South Dakota
They are apply'n a transparent type coating to the bushing, i have bought two 24 tooth sprockets from cat since january and both had this "film".Maybe they have in fact used a better bushing!
- 59K
