SledFreak
- Feb 7, 2005
- Ontario. Canada
For some reason this is different then my Apex was and I can't seem to find where the bolt is to drain the fluid from my chain case. Is the bolt off the front of the cover at the very bottom of case cover? Also, how many OZ's of oil does it hold? Reverse model...
Thanks....
Thanks....
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
take them bot out and see which one oil comes out of... i think its on the bottom and has a copper washer on it. I cant remember amount of oil tho. Im sure a search or owners manual will tell ya
yox185
SledFreak
- Feb 7, 2005
- Ontario. Canada
Thanks.....
sleddingfarmer
what kind of oil you going to run?
Trying to decide between klotz and amsoil. I like how the klotz is kinda "sticky".
Anyone running ER / Energy Release?
SledFreak
- Feb 7, 2005
- Ontario. Canada
I run Torco SCC 100% synthetic snowmobile chain case oil.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
royal purple is good stuff
mach9
May as well throw in a magnetic drain plug while your at it.
I found some last year that worked perfect.
http://www.magneticdrainplug.com/Motorcycle_Drain_Plugs/MP11.html
Get 2, they are the same bolt for both the chain case and external oil tank.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
mach9 said:May as well throw in a magnetic drain plug while your at it.
good find!
