kkraus and Wis Sledder,
I owe you boys an apology. My skid is out and I looked closely at my limiters with regard to your issues. I looked pretty well at my straps in less than perfect conditions in the trailer and thought they were fine. I was wrong. On one sled, at 122 miles, both limiters are in need of replacing. I can see the problem very clearly from above when I compress the front arm, and I can even explain why yours are failing faster than others. If the limiter moves freely around the tube of the front arm when the front shock is compressed(we're talking about the top of the limiter) the strap can and obviously does contact the track. If I compress my front arm completely several times my straps rotate freely only occasionally. I'll bet yours rotate every time. Other machines probably don't rotate at all....yet. Here's a picture of my straps with the arm compressed.
