GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
So I was able to get it apart fairly easily with the help of a ball joint separator.
I'm now trying to reassemble.
The bolt in the a-arm passes through the spindle and you have to attach the nut at the bottom.
How do you keep the bolt from turning while turning the nut?
Seems I need to reseat the bolt in the spindle somehow?
I thought putting weight back on the ski by lowering the sled from the lift might do it, but the bolt still turns.
