kawirider33
- Dec 9, 2016
- Tillsonburg
- 09 nytro xtx
Mpi stage 1 supercharger
Handle full exhaust
Dyno jet pc5
Van amburg tunnel
Assault seat
Low compression Pistons
Heavy duty rods
Curve xs skis
Custom air brushed paint
Royal distributings 09 show sled
hey need some help my xtx nytro won't start it'll crank forever but won't turn over any ideas on what to check ?
Dr. FeeLGooD
type - wont start - in the search box upper right corner of this page.
First off, can you hear the fuel pump turn on when you flip the key on?
kawirider33
- Dec 9, 2016
- Tillsonburg
- 09 nytro xtx
Handle full exhaust
Dyno jet pc5
Van amburg tunnel
Assault seat
Heavy duty rods
Curve xs skis
Fuel pump runs just out a brand new one on it will crank and sometimes the yellow warning light and oil light will come on just won't turn over it almost does sometimes but can't get it to fully start
You mean it wont crank over it just click or does nothing?
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
He does say it's cranking... By "turning over" he means starting.
Im trying to figure out if its not getting fuel or spark and if its turning over then we need to look in another area.
kawirider33
- Dec 9, 2016
- Tillsonburg
- 09 nytro xtx
Handle full exhaust
Dyno jet pc5
Van amburg tunnel
Assault seat
Heavy duty rods
Curve xs skis
Not sure what it could be other then clogged fuel rail being that the fuel pump is brand new on it but does kinda seem like a fuel issue
Pull the fuel line off the fuel rail and turn the key.. see if its moving the fuel.
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
sounds to me like the starter solenoid is bad.
That was my next suggestion.
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
the solenoids are cheap, i bought 1 on Amazon last year for $14. mrsled helped me out with that too
kawirider33
- Dec 9, 2016
- Tillsonburg
- 09 nytro xtx
Handle full exhaust
Dyno jet pc5
Van amburg tunnel
Assault seat
Heavy duty rods
Curve xs skis
Got it to start a tad bit better but it runs like #*$&@ and dosent start very good after you've rode it you need to let it sit for a while or it won't start . Won't idle nice when it gets hot wants to stall and is popping a lot not sure what's causing it I did have some race fuel in it but took that out and tried straight 91 and it's still doing the same thing
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Are you sure nothing built a nest in the muffler or even further forward in the y pipe?
kawirider33
- Dec 9, 2016
- Tillsonburg
- 09 nytro xtx
Handle full exhaust
Dyno jet pc5
Van amburg tunnel
Assault seat
Heavy duty rods
Curve xs skis
Yep seems like it's a fuel issue now but it just got a new fuel pump so all that's left to do is oxygen sensor and check the fuel rail idles for a couple seconds then shuts off
