rxwhopper
Does anyone else hear and feel that grinding noise from the track ? Cat buddy says all cats do it but it's driving me nuts. Thought was chunk of ice but was to warms today and I just took it out of the shop.
Sled Dog
Its track ratcheting extrovert drivers and fully clipped track to fix.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Track ballooning and hitting the bottom of the tunnel?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Viper has extroverts
rxwhopper
So should it be tightened. I don't even think I'm on throttle that hard.. Definitely not ratcheting.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
The track Ballooning is a normal thing.
09NytroRTX
I feel like I hear the same thing but no clue what it is
E&S
- Feb 10, 2011
I believe the toe caps are hitting the track. Tighten limiter straps as much as possible and try again.
rxwhopper
I think I may have found it. The trackingnonlynhas to be ff slightly to make it hit side of tunnel. It's been rubbing n70 km on it now
FAMILYMAN
Great, FYI they make a nice antistab kit from arctic cat. I would do that before tightening limiter straps and changing ski pressure.
RtxViper
My brothers was making noise and kinda sounded like chain case and sure enough dealer told him to finger tighten chain and then back it off 3/4 turn instead of 1/4 turn and no more noise. Maybe that helps
mn.vipernut
My xtx makes the noise also, as previously stated I believe it is stabbing I plan to try a wheel kit.
viper1xtx
mine made the noise as well in deep snow without pulling all that hard. I felt it was ratcheting because as soon as I would let off a little, it would stop making the noise. It didn't sound quite like the ratcheting sound or feel I'm used to hearing on my nytro before I put extrovert drivers on that sled. anyway tightened up the track and the noise is gone.
rxwhopper
The snow isn't crazy deep at all here. 2 feet in spot at the most. I don't have to be applying power either. Adjusted track and it's still doing it. Was perfect in shop on stands now seems to be off to the other side. Grrr. I think 4 rear wheels would make it track better
mn.vipernut
If you read some of the cat 4ms you will see it is a recurring thing. Its the front of the skid hitting the windows of the track. In powder it bunches the track in front of the skid they have anti stab kit offered right from artic cat.
