G Danko
- Mar 28, 2015
- South Carolina
- Yamaha Attaks 2006
Any chance for a picture or more guidance on where to look for the grounding blocks? I have two 06' Attaks and want to check them out in advance of having a problem.Did you check the grounding blocks?I had two that faild in my Attak last year. Same thing happend to me. Just died on the trail. There are ground blocks., three I think, two for sure in the harness along the delta box frame. Cut the wires and soldered them together. No problems this year.
G Danko
- Mar 28, 2015
- South Carolina
Where can I get a solid state red relay to carry in my spare parts bin?I just changed out my fuel pump relay for the solid state red one. I found it a bit aggravating to load the sled in my truck, drive to my destination, and when I'd go to unload my sled, the fuel pump relay wouldn't work and I'd have to remove the relay, warm it up and reinstall.
Any Yamaha dealer... I know Port Washington Yamaha has them in stock.
J McGuire
- Jan 2, 2018
- South Range, WI
- 2007 Yamaha Apex Gt
I just had the exact same thing happen to me on Sunday with the my Sled. Been going through things and still haven't solved anything yet. Have you figured it out yet.just as i was hitting the throttle on my 07 apex and it just shut right off like i hit the kill switch and it wouldnt stat back up. i cant hear the fuel pump when i turn the key on but i hear the click of the fuel pump relay, i checked the two 10 amp fuses by the battery box and they are fine as well as the male and female end next to fuses which was a little corroded but not too bad. Is the fuel pump bad on it?
