Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
2017 Sidewinder has a rated fuel capacity of 10.0us gallons
2018 Sidewinder has a rating of 8.9 gallons.
What happened?
What happened?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Wow JT....you missed this? Has been talked about since last season.
Same tanks....same as cats...holds 10gal. Gotta burp.
Dan
Dan
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Could you please explain the "burp" process?Wow JT....you missed this? Has been talked about since last season.
Dan
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Fill tank (not ALL the way to top to cap or it will get on your seat) then push down on back end. The tank will go "blluurrrpppp" when the air comes out then you can put almost a gallon more in.
geez150
My 2017 cat spec sheet that came with my sled says 8.9
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Thank you for the explanation .I always wondered what that means.Fill tank (not ALL the way to top to cap or it will get on your seat) then push down on back end. The tank will go "blluurrrpppp" when the air comes out then you can put almost a gallon more in.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
yes the spec sheet has been wrong, and still is....likely a dozen threads on this last season, same thing diff yr.lolMy 2017 cat spec sheet that came with my sled says 8.9
Rear of tank is higher then front, when filling up the air remains at rear. So if you push down on rear of sled, air rises naturally and "burps" out front. Now you can add another gal approx.
Same as doo...only diff is Rmotion has much more sag, so it is easy to ''knee'' down the rear alone to get a full burp. SW LTX will be harder then RTX to knee it down alone, a buds help gets a more full burp.
Doc Harley
- Oct 17, 2016
- Here & there
Dear lord, Dan......yes brought up many times.
Memory loss and old age go hand & hand. And for some more than others. I hate it.......
**sj**
we call it super fill....fuel cap goes back on....knee into rear of seat hard a couple times...add more fuel....procross and doos due to tank design
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
You dont want to press on seat as fuel will spit out....Knee onto rear bumper, no need to put cap on(just dont fill it to brim first time) and its easier on doo since they sink nicely with Rmo....cat not so easy, so a bud on bumper really makes for a full burp.we call it super fill....fuel cap goes back on....knee into rear of seat hard a couple times...add more fuel....procross and doos due to tank design
haha
**sj**
actually... yes... cap on... knee into seat... has worked better than rear bumper push and seems to fill more... especially with the le shocks.... seems faster at the pump line also
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I would not start telling people that....as I constantly see guys trying that and flowing all their fuel all over their seats. Inevitably someone will do it and forget to put cap on....Since tank is directly under seat, when cap is not on it the tank dents down from pushing on seat, and fuel gushes out....actually... yes... cap on... knee into seat... has worked better than rear bumper push and seems to fill more... especially with the le shocks.... seems faster at the pump line also
Also, you lose a step in fueling as you must now remove pump spout, hold that in one hand, then put cap on, then knee on seat, then uncap, fuel up.....
I leave pump filler sitting right into filler neck, burp, and then keep pumping. Where we are the lines are nuts, you want to be fast.
**sj**
Read the post Dan... cap goes back on first... never a drop..
Just a super fill... pushing on there rear with the cap off would have a greater chance of fuel on the seat...just common sense
WinterWolf
- Mar 25, 2017
- Connecticut
How bout just filling it and putting the cap on, and then that's it..so I don't get the extra gallon in..not a big deal for me. Will the sled vapor lock/not run right if one doesn't burp it??
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
How is this acceptable in the 21st century? This isn't a toilet it's a fuel tank that's as life or death important as a divers air tank when your 40 miles from a road at -20.we call it super fill....fuel cap goes back on....knee into rear of seat hard a couple times...add more fuel....procross and doos due to tank design
