sneakattak88
does Yamaha make 22 top gears and a 37 bottom? if so can i have part #?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Cat gears, the 22T with the oil holes is right at the top.
sneakattak88
thanks a bunch !!!!
DMCTurbo
- Nov 12, 2005
Gear & Chain Length Chart / MPH Gearing Chart
Chaincase Performance Calibrations - ProCross/ProClimb Chassis:
The following should be used as a guide only. Speeds are based on 12% overdrive. The gearing options below are those that allow acceptable chain tension. Any other combinations may not allow acceptable chain tension.
NOTE: 2017 M 8000 Mountain Cat and all 2018+ M 8000 models have a longer center distance and require a 96p chain with the stock 19-50 gearing.
