jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Damn.. Is that your foot Turboflash?As mentioned above, Team primaries crack on movable side down low by center roller bearing. Sounds like same situation as Winder, clutch is very thin down there. Because it's thin, it doesn't take heat very well so gets heat checked which leads to start of crack. Eventually, clutch blows apart with massive carnage and potential personal injury. See pics.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
I have plenty of these pics also, too gruesome to show here.
There was pictures from a man who had part of the sheave embedded in his forearm, I was not able to get that pic downloaded as FB took it down immediately. If anyone finds this pic, or knows who it is....send a pm.
Turboflash
- Mar 18, 2019
- Southern MN
Fortunately, no. I have compiled lots of pics of cracked/broken/exploded Team primaries which I included in my formal complaint to Consumer Products Safety Commission. I probably have 25 pics. The CPSC has launched an official investigation and I was recently notified they have now submitted a formal complaint to Arctic Cat. Arctic Cat is now REQUIRED to formally answer the CPSC. CPSC notified me they will be keeping me advised. IMO, it's NOT an acceptable solution to just replace a blown up clutch with the exact same clutch (that will also blow up!). Design modifications or a whole new product is required.Damn.. Is that your foot Turboflash?
Time will tell. Cat is still replacing "older" Team primaries (for cracks) on sleds that are many years old. My buddy just got a new one for his 2017 TCat with 4200 miles under warranty. That tells me Cat KNOWS full well there is a huge problem.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
We have forged pistons, cranks, camshafts right from the factory with 1970's clutches on these sleds.
Time for the manufacturers to step up.
I blew two primary clutches on a stock nytro.
Both times the spider broke and parts were contained in the clutch compartment.
The footwells and clutch covers need to be able to hold the flying parts. Even the side panels need to be stronger.
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
thanks for this advise..I had no idea..will vary speed to keep things wearing properly.Typically groves in the arms and sheave faces come from riding in one range too long and most of the time. Say you ride at a consistent speed like say 60 MPH for miles on end.
Preacher
I have replaced my clutch with a PB 80. I feel like I should change the secondary and just avoid this issue all together.am I being to reactionary or will the problem present itself in the secondary eventually as well
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
I believe the factory will never respond. the best way to limit liability is to deny or ignore an issue. It's lawyers. Until they decide they are going to lose more money in lawsuits, they won't acknowledge or remedy. Sad. JMO
I think the likelihood that a secondary failure would cause a serious injury is pretty low. Obviously it would suck if it ruined a trip, but so far it doesn't seem as widespread as the primary failures.
I for one am going to be replacing my secondary once the "new" ones are available. I have heard directly from the source that these "new" secondaries will be available soon.
I'm very interested in seeing what these look like and I know for sure it'll be a perfect match for my TAPP primary.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Who is making this new secondary ??? Yamaha
No. Not Yamaha. At least not that I'm aware of.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Is this clutch on sidewinder with tune? Holding up?I have replaced my clutch with a PB 80. I feel like I should change the secondary and just avoid this issue all together.am I being to reactionary or will the problem present itself in the secondary eventually as well
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The Yamaha stock secondary is fine. No worries there.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I believs Dave at powderlites, the makers of the TAPP, is working on something. It would have to be better than the STM or Pro-4 secondary's. Those I don't believe are any better than stock.Who is making this new secondary ??? Yamaha
- Sauk Prairie, WI
- www.ty4stroke.com
I think a large percentage of these clutch failures are cause by the crap bushings in stock rollers. If you look at more of the pics posted here or on FB where failures have occurred, the bushings are egg shaped. If the pin is in contact where the bushings is worn the weight will swing out passed the roller and go BOOM! At the very least, replace your stock rollers as soon as humanly possible with Thunder Products or STM rollers. Based on my experience, the stock rollers are good for about 800 miles with a tune before they are done. But, why risk it? Additionally, even if you had an older style Yamaha primary installed, if a weight flys out past the roller, it will be catastrophic. REPLACE YOUR ROLLERS!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I would think this would be everyone's recourse for this issue which would force Yamaha to acknowledge there is a problem and issue a safety recall. They've done it for much lesser problems. All of you affected by this should report it to the Consumer Products Safety Commission in the US and Transport Canada.
If a recall can be issued for weak bolts on the passenger handles, I'm pretty sure they can for exploding clutches that can send shrapnel into your body.
