I still say they stole the idea for these scratchers from the innovative people on this forum. They should donate something to this forum for every set sold.
fireplug98
- Dec 16, 2010
Sled Dog said:I still say they stole the idea for these scratchers from the innovative people on this forum. They should donate something to this forum for every set sold.
Who else makes these ?? Web site ??
SEARCH
Home made cable scratchers its almost the same thiing other than the different kind of pick used and hooked up in the exact same spot. Yamaha copied them from here.
SRXSex
Just installed a set, yes if you look close there is a left and right, that way they point inwards to form a V spray at the track. Also you mount them on the inside of the sway bar link. Don't forget to use red lock tight on the carbide studs. Part number on the package was SMA-ICESC-01-ST
grumpysanta
yes new updated ones have a completely different mounting fitting see pics. on yam. can web site,
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Sled Dog said:SEARCH
Ya I remember them, people where making them out of tailgate cables. Now you know Yamaha is here on TY Forums! LOL
Puppe
Since when?Sled Dog said:I still say they stole the idea for these scratchers from the innovative people on this forum.
Those kind off scrathers have been sold at Finland since 2004 first for overheating Warriors...
Hey (fireplug98) or Tommy J SHHHHHH add your location to your description.
You missed a great ride on Saturday - hope your back is doing well. Nice test run Rush City to Luck WI down south crossed the St Croix and back up 142 miles.
Yamadog (Steve K)
Yamadog (Steve K)
paul55ro
Ice Scratchers
Installed pair of ice scratchers on 2011 Apex SE stabilizer linkages, after 170 miles on lake running , one of cables fragmented. After inspection of cable asm I found area above carbide tip had marks which came from the cable bouncing of the bottom of the frame tunnel. Now the underside of my frame looks like someone took a ball peen hammar to it.
Caution: These cable assemblies are good for low speed . Need to devise a method of storing, when running over 50 k/h. Also tip should be padded with a soft material ie rubber to eliminate tunnel scarring.
Going to dealer today to discuss further
