RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
With the yamaheater i didn't see what the difference was between the
"booster" yamaheater plug&play and the regular p&p can someone explain?! thanks jason
apexg88
I have installed a yamaheater on my sled but have no idea what you are asking lol..
My advice would be to PM ROCKERDAN and he'll help you out
apltx08
If you read Rock's thread he explained about some of us with '08 like myself that might need a "BOOSTER" with the YAMAHEATER set-up cuz of certain '08 having more resistants and needing more POWER to get MORE heat to our handwarmers, mine are OK, better than stock but could use a LITTLE more!
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- Comstock Park
yamaheater
so i should buy the boosted one to be safe i have a 2006 attack? this way i get the most heat out of the kit?
mshabaz
- Aug 16, 2006
I just installed em on my 06. Have yet to run with em though. But here's the difference: our heaters do not warm up when at idle or slow speeds, so our warmer are playing catch up when we start to ride. Even then they don't really get hot enough to do the trick when it's cold out. The yamaheaters will start warming the bars the minute the sled is running, thus you're not starting out w cold hands. U still use your blue button to adjust temp after they get warm. Also when they are on it's like having a setting a notch or two above the current hi. So far in the garage after a cpl min of running they are definitely very very hot. Hope this helps. Btw plug and play takes all of 20 min to do.
apltx08
Re: yamaheater
No you don't need the BOOSTER with '06, like I mentioned its '08 that need a BOOST...I did my Bud's '06 and they get HOTTT!!! you'll be fine
RacinJason15 said:so i should buy the boosted one to be safe i have a 2006 attack? this way i get the most heat out of the kit?
mshabaz
- Aug 16, 2006
maybe i'm missing something also,,is there a new type of yamaheater with a booster?? different than the regular yamaheater??
apltx08
Its an EXTRA component that you add between your YAMAHEATER and GRIPS to BOOST output even more that Rock came out with cuz of some grips having more resistants...like myself, '08 seem worse and don't get as hot! and by adding this booster it makes them nice and TOASTY!
apexg88
I LOVE HOT HANDS!!
