mtkaboater
Amzoil 0-30 in the Vector. 10,000 miles on it now. Napa Gold filter 1358 I believe.
Grimm said:What's your reason for not choosing Amsoil tapex?
tapex_07 said:in a test my old engine builder did, the amsoil ran away from heat! Where others were attracted to the heat!!Grimm said:What's your reason for not choosing Amsoil tapex?
tapex_07 said:I use to be a dealer for amsoil until I started having problems.
mach9 said:I have nothing against Amsoil in fact I've used it here and there.
But here is what I know.
Run away from heat.
This usually occurs at high temperatures of the piston / rings.
The excessive heat results in rapid piston expansion and possible failure of the lubrication film.
This condition is called "runaway" surface ignition.
This can happen under sever conditions but likely with a lower quality oils.
Oil is suppose to be designed to pull heat away and the better quality oil is attracted to the hot metal surfaces to keep surfaces lubricated.
I find interesting is this part of the reply.
tapex_07 were you building some race motors when you were a dealer and how long ago was that?
GT03235 said:i just did a filter and oil change on the nytro and phazer with mobil1 0/30 w fully synthetic time will tell.![]()
I got it from wally world so i was lucky by the semm of thingsIrv said:GT03235 said:i just did a filter and oil change on the nytro and phazer with mobil1 0/30 w fully synthetic time will tell.![]()
Good choice IMO![]()
dilligaf said:Using Yamalube synthetic. Can't go wrong with what the manufacture specs. Some (or should I say a majority) of us will really never now what works best since we won't hang on to our sleds long enough to find out. If someone has high miles on their sled, be nice to know what they used.
