Yellow blinking engine light
Killer. That was the info I was looking for.
So just to recap, when the yellow light flashes the computer is telling an error code. Mine were 84 and 42. TORS and the speed sensor. Got it.
One more question: is the speed sensor bolt supposed to loc tited?
Thanks guys I really appreciate the help
That's right.
Is that the bolt that had fallen out? The service manual does not call for locktite on that bolt.
Torque it to 17ft.lbs
I would also check your speedo sensor and make sure nothing made contact with it. If it has any marks on it, good chance the bearing is going south and speedo gear touched it. I don't think it's common for the bolt to just fall off.
Dan
Hey I got code 35 I have got this before and starter went and fried the ecu I replaced the ecu and sled has been running good. Took the sled for a good ride today and just started to show the code again and I tested the coil and seems fine what else could cause this.
