Stone9
Anyone who has.this setup, did the kit come with new ski bushing s? I bought mine off a guy on here and I used stock ones and have a lot of play
biglines
They don't come with new bushings. Maybe find replacement brass inserts for the zbros spindles and see if that tightens it up.
Stone9
Stock inserts your saying?
biglines
Stock zbros inserts that are pressed in the spindle. I am guessing those would be worn rather than the steel yamaha bushing that the ski bolt goes through.Stock inserts your saying?
edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
The Z-Broz spindles come with bushing pressed into the lower mount for the skis. But do not cone with any of the A-arm bushing. The stock yami bushings maybe different than the Z-broz bushing & that could cause the slop in the set up. You should be able to contact Z-Broz & get new bushings for them. I've had really good luck working with them. Give it a try but I can't see those bushings wearing out without a ton of usage.
Stone9
Yes I am talking about the ski mount. The inserts or bushings are sloppy. I need to take it apart to see if I can tell which. I have left message after message with z broz and no call back.
edge_232
- Jan 15, 2014
- Madison WI
That's seems strange since I've never had that problem from them. Well just keep calling and hopefully you can get through to them.
Stone9
got a hold of them. they took care of it. thanks guys
edge_232
- Jan 15, 2014
- Madison WI
Glad to hear it worked out!
