tkuss
Over winter i bought a 144" extend kit from a guy on the internet, it came with everything but the ZX-2 extend manual and the bolts.
Here is a picture of what I have right now.
Can anyone help me out, and tell what else I need, do I just get bolts that fit in the holes from a hardware store and call it good. Or are some of the holes not for bolts.
Any help would be much appreciated.
A response from me may take a few days
PM me your email and I'll scan my 151 ext kit manual. Should be similar. It will give be a base line to start with.
Vandelay Industries
- Apr 8, 2008
- Nashwaak Valley, NB
- 2013 Nytro XTX
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Since I just did the 144 extension I can help you out the best I can. After reviewing the 136 extension manual, I noticed it was somewhat the same. All except the inside I used the aluminum long plate instead of the one that said zxtend on it. I got both in my package. But the 144" manual says to use the one with the label on the outside and the longer aluminum plate on the insides. I can take some pictures, I think I might have took some with it off the sled.. As for bolts Ill have to look at my manual to see what they say.
Subaru2006
Subaru2006
tkuss
Thanks guys, I emailed Denis Boivin as well yesterday, and he emailed me the 144" manual, so I should be set.
Thanks for taking the time and helping me out though.
http://docs.google.com/gview?a=v&pid=gmail&attid=0.1&thid=121c0a0bc72a4b64&mt=application/pdf&pli=1
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Do you think there is any way to modify the mount of the Zxtend so that it would have a tip up?
tkuss
kinger said:Do you think there is any way to modify the mount of the Zxtend so that it would have a tip up?
No I don't.
I will take a bit of a look at it though, but I think you would need plastic with a different mold.
kinger
- Jan 17, 2005
- Clear Lake, IA
yeah I was thinking maybe adjusting one hole and grinding some of the plastic off in spots to accomplish the tip up. Would love to get 6 degrees out of it.
tkuss
Anybody have problems with not being able to get the rear axel in place with an extended ZX-2?
I have extended to 144" and need a 2" shorter rail extension to fit my 144" track. I will take pictures tommorow. I have few ideas on how to fix it, but will contact Boivin and see what they say.
tkuss
Found out I have a 141" track and not a 144"
Not Boivins fault, its mine for not check part #'s when I buy used stuff online
