STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
What are the majority of ZX-2 guys running for pin positions? state pins locations and riding style
Shane
- Dec 21, 2004
- Niskayuna, NY
- www.fa.ml.com
- 2014 YAMAHA VIPER LTX SE
2015 Ski-Doo 800 XRS Renegade
2012 Ski-Doo 600 ace
2010 Ski-Doo 600 e-tec GTX Limited
2007 Polaris Dragon 120
2/5 some aggressive some cruising trails
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
1/4 - rough trail and off trail riding for the most, some lake and rivers with high speed riding past 210 kmh or 130 mph. This setting gives me enough transfer while still coupling enough to keep the skis on the ground when turning under light throttle. WOT and skid goes up 4" to 1ft depending on speed and hookup, I need to be able to throttle the front end over the moguls and when off trail in the loose stuff. I never got stuck even once last year, I really try not to LOL
Jigger
2/4 preset 4 or 5
Grimm
I ended up using the 2&5 pin positions last year with my Vector.
tkuss
What differences do you notice going from 2-4 to 2-5 on the revolver? Is it a bit harsher ride?
Grimm
I didn't really notice a harsher ride, maybe a little in the small bumps, but I felt it kept the skis planted down more and not as tippy, which I felt was needed.
kinger
I use 1/4 with preload on 3. Keeps the skis down for groomed trail riding and ditchbanging but if you get in the bottomless fluff will stick the skis straight up in the air so you can catwalk it. Its fun
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I might try 2/5 tomorrow and try 1/4 later in the day. I am trying to get rid of too much transfer in tight trails so 1/4 might not work for that--maybe better for big trails?
kinger
1/4 gets me 4" or so of lift at take off and with the GYTRs compression clicker on 12 of 12 adjustments and my 13mm sway it rails the tight twisties of WI, I can keep up or beat any sled in the woods.
