kinger
Jeff/AD bolvin,
Is it possible for the cam to rotate too far in one direction and cause a binding problem?
Are there any special tips or tricks to look for when turning the revolver?
Any tips would be great. Thanks!
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
revolver
Kinger
I think you may be on to something here. Mine works fine but others don't collapse. I'm curious to see how Jeff responds.
Kinger
Grimm
Maybe give him a call.
kinger
I would call but wanted him to reply so everyone can see it.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I have mine in the 2 and 4 position (stock setting). Do you have a pic on how yours is adjusted, we could post pics here to make a comparison, you may have it adjusted the wrong way. Just a thought
kinger
That is the same position as mine, its not rotated but I'm asking the question in advance for when I begin to tune mine. Wondering if it will rotate on its own under track tension and not go back without a fight or go back wrong.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
It moves much easier if you take the weight off the skid. Mine will only go so far and stops. I don't think it is possible to screw it up. It will rotate to different positions with the sled sitting on the ground, but takes a little more effort to move it.
