DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Just a heads up for those green loctiting the bearing into the housing. I noticed upon removal of my stub shaft assembly that my shaft moved inwards. The bearing was flush with the housing on the face so everything looked fine visually after removing my primary. Needless to say I won't be locking the bearing down anymore. Other option would be to lock the bearing on the shaft as well but I don't like that option as I feel on a belt blow something has to give and I wouldn't want the full force going thru and possibly cracking a clutch.
I would try locking both. I think that machining tolerances are at play here and it originally was designed to not move at any point. Clutch was also designed to be on a shaft that doesn't move. Lock them both. The belt is the Safety. We may find in some cases once it slips it will forever be weaker fit due to the movement and assembly and disassembly twice. Might be forced to buy new one. But I would not lock a new one down till a issue shows its ugly head.
I quit doing this as it can only move a little anyway. The inner bearing prevents it from moving any further.
DMCTurbo
- Nov 12, 2005
Y
Yes but my biggest concern is it throws out your offset and you may not be aware.I quit doing this as it can only move a little anyway. The inner bearing prevents it from moving any further.
Up to 3/4mm max.Y
And why worry about that when almost everyone on this site doesn't have their secondary locked except Knapp and myself. Stock secondarys float about 6-8mm.
Do you lock yours?
DMCTurbo
- Nov 12, 2005
Yes I run it locked.Up to 3/4mm max.
Do you lock yours?
I'm not sure what the float has to do with this to be honest. Stub shaft moves in it throws off your offset plain and simple.
That was my whole point of the thread.
The secondary is what it's measured from.Yes I run it locked.
DMCTurbo
- Nov 12, 2005
You are confusing me. Once you have your offset dialed in and your stubshaft moves in due to a blown belt. Your offset is now out to lunch.
It's only about .5-.75mm max that it can move.You are confusing me. Once you have your offset dialed in and your stubshaft moves in due to a blown belt. Your offset is now out to lunch.
Again, in stock from the secondary moves far more than that.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Mine is locked downUp to 3/4mm max.
Do you lock yours?
I'd like to see someone make a belt adjuster and changing tool that locks it up from floating.
BOP, or Thunder?
BOP, or Thunder?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Wow, I never thought the shaft would move in the bearing. when I changed the bearing in my 17, it took a lot of pressure to get it to move, and when it did move the press was about maxed out and what a bang it made when it finally let loose.
When I put it back together I green loctited it all including the shaft. I didn't want it moving at all anywhere.
Turboflash
- Mar 18, 2019
- Southern MN
Agree. Surprises me too. I've had same experience using my press - took max pressure to get stub to move in bearing.Wow, I never thought the shaft would move in the bearing. when I changed the bearing in my 17, it took a lot of pressure to get it to move, and when it did move the press was about maxed out and what a bang it made when it finally let loose.
Fast
- Sep 25, 2018
Mine has been locked since new, no issuesUp to 3/4mm max.
Do you lock yours?
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
Is taking the float out as simple as stopping any side to side play in the secondary as it sets with the machine off and the belt up in normal position?
