Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Thanks for finding this. Much appreciated. Funky looking piece of Carbon Fiber (my guess) for a front rear suspension arm!US11319024B2 - Rear suspension system for a snowmobile - Google Patents
A snowmobile includes a chassis, at least one ski, and a skid frame that includes one or more slide rails extending longitudinally, rear idler wheels, upper idler wheels, and a rear suspension. The rear suspension may further include a flexible, composite member, a rear shock connected between...patents.google.com
Also looks like one of the weber guys is working at arctic cat now on the ATV engines
Engine-US11578647B2
Embodiments are directed toward an engine. In some embodiments, the engine includes a water pump and a balancer shaft. In some emb...www.patentguru.com
Wonder if cat will make a 9XX turbo twin to fit in the catalyst.
Skurtenb
- Dec 29, 2022
- Central WI Weston
- 2023 thundercat, 2024 ZR 9000 RR, 2013 F800 LXR, 2008 F6 lxr
That front rearcsuspension arm reminds me of the old fiberglass overload spring on the 2 ups. It actually worked very well
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
The fiberglass overload springs are still used on 2up yamacats. They've been used since the early 90's(on Cats), simple and affective.That front rearcsuspension arm reminds me of the old fiberglass overload spring on the 2 ups. It actually worked very well
northwindwinder
- Apr 12, 2023
- St. Germain
- sidewinder gt
Just sticking to what works. The last Kitty Cat,1999,had the same springs on the skis.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
From an initial scan of the drawings.
The torque arm in this design is a tuneable multi-rate spring. The design is subtle, and it relies on the torque arm mounts being captive at both ends. It provides different values of spring rate based not only on displacement of the spring, but also distortion of the spring and on where the load occurs. This allows it to react differently to loading the front of the skid vs the middle or rear of the skid.
Take a fishing pole or any bendable rod, hold it out horizontal in front of you. Bend your hands inward such that you create an arc in the rod, that is one function, the other comes from distortion. Take the same rod, and without twisting your hands move one hand up and the rod takes on more of an S shape, that is the other function. In either case, when travel exceeds some amount the adjustable transition point kicks in and you get a second spring rate.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
This is super impressive. This is a catalyst 154 mountain sled WET! Some of the mountain manufacturers are already showing 25+ pounds of weight savings through aftermarket parts. AND the new 850 is LIGHTER.. we knew it was going to be light, nice to see a real world result.
RAMSOMAIR
Let’s hope they didn’t use tinfoil like Doo did a few years back to get weight down and then the bulkhead would split when you hit a snowball
ricks-rocket
- Dec 13, 2004
- Wales,Wisconsin
- 2023 yamaha sidewinder srx le eps
Weight is not everything. You still have to look at it. It’s horrible to look at. Worse in person.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The mountain guys have been beating the crap out of them. They don't seem any more or less durable than the doos and poos they are riding.. they all break.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
In back country riding weight is extremely relevant. Too early to make any real claims about durability but the 600 is getting very good reviews in the mountains where it is riding amongst 850s and 850 Turbos with plenty of Poo 9Rs thrown in. If I'm in the market next spring I would order an 858 154 for next season. Looks are subjective. To me the Catalyst is great looking.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Agreed. I have seen them in person. I think they look great. And that new gauge looks killer. If you could retro fit that new gauge to the Procross I bet there would be many takers if the price wasn't stupid.To me the Catalyst is great looking.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
It is in the works.If you could retro fit that new gauge to the Procross I bet there would be many takers if the price wasn't stupid.
Other thread: https://ty4stroke.com/threads/looks-like-a-new-display-gps-in-the-works.162988/post-1620036
stgdz
- Mar 27, 2021
- Buffalo MN
2027 catalyst
What's next? Power adjustable seats? Power mirrors? New derriere? New 600ish engine? Back up camera? Thoughts?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
The Catalyst chassis with a new skid, the current EPS, and a Winder engine configured like the EXT minus the purple or ditch pickle green could be sled of the year
stgdz
- Mar 27, 2021
- Buffalo MN
Seen more than a few of those EXT's on the trail for the limited amount of trail riding I have been able to do.
- 20K
