OGGY DOGGY
I am putting my 04 Griz carb, exhaust and intake back to stock, does anyone know what the stock needle jet and clip setting is ? I did not mark it down when I put the dyna jet kit in, My exhaust is too loud for hunting and my fellow riders say they need ear plugs when riding behind me.
main 153.8
and middle notch on the needle
joel
- Nov 12, 2006
I WANTED TO LEAN MINE UP A BIT BUT AFTER I TOOK THE CARB APART I FOUND THE I DONT HAVE DIFFRENT CLIP SPOTS, ITS A 2006. IS THE O4 DIFFERENT?
that I am not sure...I have 3 positions on the 02 that I have and figured nothing has changed until the FI700
joel
- Nov 12, 2006
IT HAS A CLIP BUT NO OTHER GROVES . ILL TAKE IT APART AGAIN BUT THE RUBBER DIAPHRAM IS TUFF TO GET BACK ON.
OGGY DOGGY
I got mine all back together in stock form and it runs great , I guess I did not need all that aftermarket stuff after all, the 04 has 3 grooves on the clip I got mine in the middle, now I got all this stuff to sell on maybe on e-bay, I tried the dynatek ign. and it does seem to have a more positive effect when everything else is stock. Although I dont think I will use it.
joel
- Nov 12, 2006
I TOOK MY CARB APART TO TRY SHORTNING THE CARB SPRINK, I TIDE IT SO IT WAS A INCH SHORTER RATHER THAN CUT IT TO SEE HOW IT RUNS IF IT SUCKS I CAN UNTIE IT. BUT THERES NO CLIP GROVES. THERE IS A THIN WASHER THAT SITS ON THE SLIDE THEN THE CLIP IN ONLY ONE GROVE A PLASTIC PEACE KINDA LIKE A WASHER ( ABOUT A 1/8 INCH THNICK THENA THICKER WASHER AND THE SMALL SPRING AND THE PLASTIC PEACE THAT CLICKS INTO THE SLIDE........
hmm, maybe a jet kit would help... then you can set your needle
joel
- Nov 12, 2006
YEAH WHEN I TAKE TO AIR BOX LID OFF AND THE FILTER OFF IT RUNS A LOT BETTER AND REVS OUT NICE AND QUICK SO I THINK IM RUNNING A LIL RICH AND FROM MY EXPERIENCE THATS A NORM FOR A FACTORY MECHINE
if you drop a main jet size, that will also make it leaner on the needle...
joel
- Nov 12, 2006
ANY IDEA HOW MUCH I SHOULD TRY.... I DONT EVEN KNOW WHATS STOCK
stock is a 153.8, if its the same as my 02, you could drop to a 150
OGGY DOGGY
JOEL said:I TOOK MY CARB APART TO TRY SHORTNING THE CARB SPRINK, I TIDE IT SO IT WAS A INCH SHORTER RATHER THAN CUT IT TO SEE HOW IT RUNS IF IT SUCKS I CAN UNTIE IT. BUT THERES NO CLIP GROVES. THERE IS A THIN WASHER THAT SITS ON THE SLIDE THEN THE CLIP IN ONLY ONE GROVE A PLASTIC PEACE KINDA LIKE A WASHER ( ABOUT A 1/8 INCH THNICK THENA THICKER WASHER AND THE SMALL SPRING AND THE PLASTIC PEACE THAT CLICKS INTO THE SLIDE........
I checked the carb diagram and the way you explained the needle layout is wrong unless they changed something midstream in production , it goes slide, washer,plastic washer, clip ,washer ,then small spring and retainer cap.Thats the same as the 04 except I got 3 grooves and you got 1. Go to www. yamahaofsi.com for complete exploded views. I hope this helps, I did mine and it seems to run smooth.
BURMAD69
What about the 05 carb anyone have that apart yet? Do thery have multiple grooves?
