04 Grizzly carb question
04griz660
I pulled the carb to clean it and check for debris and found some jets clogged. I pulled the rest of the jets out to clean. I checked the shop manual for re installation and came read that you need to replace the pilot jet back the same amount of turns as you took it out. Problem is I didn't check before I pulled it out. So I need to know where to set the pilot screw? Any help ?
not to worry.... that the fuel screw , if you pull that out.... you are talking the pilot, next to the main inside the bowl?
yes I pulled the piolt next to the main jet. But what is the shop manual talking about when it says turn piolt screw the same amount of turns as you took it out?
I would think not to over tighten, maybe they thinks it importain to align the small pilot holes in the shaft with something but I have never heard of anything like that.
