fourmile
- Feb 28, 2018
- Janesville, WI 53548
- 20005 Yamaha RX1, Yamaha 2005 RS Venture, Yamaha 2014 RS Venture
My 2005 RX-1 has been running super without any starting issues. It has about 5500 miles on it. On the trail today after riding about 80 miles I lost the gauge cluster/speedo. I assume I also lost my lights. After maybe 5 miles the engine started to sputter and did not have much power. It was also backfiring some. I stopped and then tried to get regoing but it didn't have enough to go forward. I shut it off and then tried to restart and I had nothing left on the battery. I w.as able to get it towed back home. I checked all fuses including the two main. They all check good with a meter. I would appreciate suggestions for my next troubleshooting steps.
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
Fully charge battery, check stator output. If the sled is not charging it's usually the stator or rectifier/regulator. There are some tests you can do on the stator also
https://ty4stroke.com/threads/stator-resistance.76094/
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
First check=battery,with multimeter what is voltage at battery&follow to fuse block.also have known issues with corrosion at electrical connector at key switch.My 2005 RX-1 has been running super without any starting issues. It has about 5500 miles on it. On the trail today after riding about 80 miles I lost the gauge cluster/speedo. I assume I also lost my lights. After maybe 5 miles the engine started to sputter and did not have much power. It was also backfiring some. I stopped and then tried to get regoing but it didn't have enough to go forward. I shut it off and then tried to restart and I had nothing left on the battery. I w.as able to get it towed back home. I checked all fuses including the two main. They all check good with a meter. I would appreciate suggestions for my next troubleshooting steps.
fourmile
- Feb 28, 2018
Thanks smallheads. I will look into that. FYI - Regulator was replaced a year ago.Fully charge battery, check stator output. If the sled is not charging it's usually the stator or rectifier/regulator. There are some tests you can do on the stator also
fourmile
- Feb 28, 2018
Thanks Brotherdan. I will check the battery issue and the key switch.First check=battery,with multimeter what is voltage at battery&follow to fuse block.also have known issues with corrosion at electrical connector at key switch.
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
could still be other wiring as stated above too. I'm guessing if you charge the battery the sled will start then just figure out why it's not charging, fairly simple system.
fourmile
- Feb 28, 2018
I agree. I think the battery is a victim instead of the cause. Something caused the gauge unit to die causing the other controls (TPS,TORS,etc.) to flake out as well. I was shocked when all the fuses checked out as good.could still be other wiring as stated above too. I'm guessing if you charge the battery the sled will start then just figure out why it's not charging, fairly simple system.
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
it won't blow fuses when the battery dies, basically just like a car it will run until there is not enough voltage to keep it running, your gauges quitting and it missing is a classic case of losing voltage. CDI controls everything and it needs voltage to run. You should get roughly 14v @5k rpm, at idle I get a little over 13v. If it is the stator it's a fairly easy job for most.
fourmile
- Feb 28, 2018
That makes a lot of sense. I will check it out. Thanks for your input.it won't blow fuses when the battery dies, basically just like a car it will run until there is not enough voltage to keep it running, your gauges quitting and it missing is a classic case of losing voltage. CDI controls everything and it needs voltage to run. You should get roughly 14v @5k rpm, at idle I get a little over 13v. If it is the stator it's a fairly easy job for most.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Had to do it on my old 03 RX1, yes pretty easy job.it won't blow fuses when the battery dies, basically just like a car it will run until there is not enough voltage to keep it running, your gauges quitting and it missing is a classic case of losing voltage. CDI controls everything and it needs voltage to run. You should get roughly 14v @5k rpm, at idle I get a little over 13v. If it is the stator it's a fairly easy job for most.
that is all good stuff to check and will most likely be the problem. mine was a bit different but i did still have battery power so make sure you get there first.
YukonMP
- Dec 25, 2014
- Yukon Territory
Another thought, you mentioned the regulator was replaced last year. Lots of the guys on here have poor experiences with after market electrical components vs OEM. Just a thought, you likely have all you need to sort this one out. Good luck.
fourmile
- Feb 28, 2018
That was a good call YukonMP. I was not getting more than 12 charging volts to the battery. One of the four diodes in the voltage regular failed multi-meter tests. I swapped it with the regulator from my 2005 Venture and saw the charging voltage return to 14 plus volts. The regulator was about a year old. I purchased it from what I thought was a reputable company (not a Yamaha parts store) . It just could have been one of those things. Thanks for everyone's help.Another thought, you mentioned the regulator was replaced last year. Lots of the guys on here have poor experiences with after market electrical components vs OEM. Just a thought, you likely have all you need to sort this one out. Good luck.
