yamajake1
looking for some suggestions. The primary needs replaced due to the grooves in the sheaves. Would I be better off replacing the whole primary with a Team or Comet....or would just purchasing a low mile used YXVC clutch and rebuilding it be the way to go? If I go the rebuilt route, can anyone recommend any aftermarket clutch weights that will work on the stock YXVC clutch?
Thanks!
Thanks!
You could send the clutch to a shop like Ulmer Racing. They could cut the faces to remove the groove and install a clutch kit for you.
Just had mine refaced locally.
http://www.ulmerracing.com/index.htm
