Have a look around the site, I'm sure its been posted. If you can't find I'll post later sometime.How do I get into diagnostics mode? Sorry in advance if that’s a stupid question as it could be in the frequently asked.
No, that is the rectifier/regulator.im pretty sure that module way up front is the ignition module also.....the one w the fins on it...... that was one of your problem areas....... maybe little bastards chewed something else
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
oops my badNo, that is the rectifier/regulator.
fireman1069
I can find diagnostics mode but can’t find how to spark test.Have a look around the site, I'm sure its been posted. If you can't find I'll post later sometime.
fireman1069
Ok so I figured out diagnostics mode from a nytro post. Not exactly same codes because 3 cylinder but close enough. Did spark test, which is damn cool by the way, and had spark on #1 cylinder but nothing on the other 3. As I’m looking for anything along the harness for a break or cut I felt something hot. It was the #4 coil. Mind you the key was off and nothing touching it. I unplugged it right away. I put that on the #1 wire to see if it still worked. I turned it over and it still works. So I unplugged the coil harness and checked it over. Nothing appears to be wrong with it. All wires look good. So somewhere from the coil harness plug back to ecu? If this makes sense to anyone please chime in.
Cylinder 2 is 31, 3 is 32 and 4 is 33Ok so I figured out diagnostics mode from a nytro post. Not exactly same codes because 3 cylinder but close enough. Did spark test, which is damn cool by the way, and had spark on #1 cylinder but nothing on the other 3. As I’m looking for anything along the harness for a break or cut I felt something hot. It was the #4 coil. Mind you the key was off and nothing touching it. I unplugged it right away. I put that on the #1 wire to see if it still worked. I turned it over and it still works. So I unplugged the coil harness and checked it over. Nothing appears to be wrong with it. All wires look good. So somewhere from the coil harness plug back to ecu? If this makes sense to anyone please chime in.
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
high resistance can cause hot wires. check from ecm to coil with ohm meter. (both circuits) ecm and coil unplugged(.5 ohm cool maybe even 1.0 .sometimes meters are off)
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
ecu is in the front burried a i little. sounds like a nice place for mice
fireman1069
Yes that area is where the damage was done. I’ll try that tonight thanks!! Damn job is getting in the way of important things!ecu is in the front burried a i little. sounds like a nice place for mice
Do you understand that there was only supposed to be spark to #1 and not the other three with the test that was performed?Ok so I figured out diagnostics mode from a nytro post. Not exactly same codes because 3 cylinder but close enough. Did spark test, which is damn cool by the way, and had spark on #1 cylinder but nothing on the other 3. As I’m looking for anything along the harness for a break or cut I felt something hot. It was the #4 coil. Mind you the key was off and nothing touching it. I unplugged it right away. I put that on the #1 wire to see if it still worked. I turned it over and it still works. So I unplugged the coil harness and checked it over. Nothing appears to be wrong with it. All wires look good. So somewhere from the coil harness plug back to ecu? If this makes sense to anyone please chime in.
fireman1069
No I did not understand that. That’s very helpful. However I did turn it over and there was no spark on those either. Now that I understand that I will go back and check again.Do you understand that there was only supposed to be spark to #1 and not the other three with the test that was performed?
fireman1069
I’ve looked over the harness from coils back to ecu and cannot find any issues with the wires. Ohm tested to about .4. Ohm tested coils and all are at 1.8. If I test the coil terminals with multimeter when turning it over I’m getting different readings from all 4 at the point each is to fire. What sends the signal to the ecu for each cylinder to fire? Cylinder identification sensor? And why spark on #1 but not the others? I’m running out of ideas. Still not totally sure of the severed brown (chocolate) wires either. Waiting for Travis at BOP to get back to me also. Anyone with a wire harness from one these that can shed some light would be appreciated so I can at least take that out of the equation.
Can you post a good picture of the electrode end of your spark plugs please?
fireman1069
The old ones are still in it. I have new ones to put in when I figure it out so I’ve been testing with those. We’re you hoping to read the plugs?Can you post a good picture of the electrode end of your spark plugs please?
Put BRAND new plugs in and try startingThe old ones are still in it. I have new ones to put in when I figure it out so I’ve been testing with those. We’re you hoping to read the plugs?
