06 apex no traction on rear of sled.
06_apex
PEI
Canada
2022 sidewinder ltx le
hey guys the rear of my sled feels loose when I drive it.. it slides in the corners when I let off and fishtails with lots of spin.. I have my transfer rod set to wheelie mode so that is the most transfer I can put to the back of the sled correct? I have my front shocks loose as the can go and then tightened 2 turns but still a little bit to much ski pressure. My track is a 1 1/4 ripsaw with 144 studs and up front I have 6 inch duels under the skis.
What can I do to get more traction to the back and what setup works best for you. my sled is an apex er.
thanks guys.
Im not sure what position it is in now. I assume I have to loosen it a hole and see what it does
Check it out. Trying going one hole lower. This will take some pressure away from the skis and back into the skid.
