exarticcatrider
oil puddle under sled cant find source..only thing it might be is hose on bottom of oil tank.any body have same issue??
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
If from the right side it could be the oil tank leaking. Check to lower panel under the tank.
exarticcatrider
checked oil tank looks dry just the hose is soaked.drained the oil and pulled hose but dont see any cracks in it any where
APEX 06
- Apr 30, 2009
- Sheboygan, WI
They leak where two parts are join.
wedge
- Jan 15, 2012
- Twin Lakes, WI - Ironwood, MI
- www.statelineadrenaline.com
- 2008 Yamaha Apex GT 40th Anniversary
There was also a problem with the pan having really small stress cracks in them in an area that is not easy to see.
exarticcatrider
well i ordered new hose hopefully that is the source..any of you guys had a bad hose?
stevieu1
just found the same thing on my 06 er a couple days ago. haven't had time to investigate
Jimmy G
I had the same problem last year. Never saw any oil until sled warmed up and noticed small crack on the right side of oil tank. At first, I thought it was the hose until I removed the tank.
exarticcatrider
well put hose on tonight tightened the clamps as tight as i could and you can still spin the hose a little bit on the fittings...wtf brand new hose is this common???
exarticcatrider
well put the oil back in still a puddle by next day....was like wtf well drained and pulled tank and found cracks on both sides of tank by bottom mounting hole... used the tig and welded back up no leaks
