yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Does anyone have any good ideas how to split the Y pipes. have 1 broken flange and 1 cracked. Also whats the best replacement or fix? Have it all tore done just cant get the split..
Do you mean separate the Y pipes from the muffler pipe? If so then make sure you have the two clamps lossened off. Keep the Y pipes bolt on the front hanger. Beat the exhaust back with a block off wood across the muffler and a large hammer.
Replace the Y pipes with stainless steel replacement pipes.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
yes.. I have done this and no luck.. gonna try a ratchet strap tomorrow after work..
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
Got it apart... Has anyone tried the flange repair kits? With success?
They have been discussed in the forums. A quick search should reveal an answer for you.
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
I used them on my Attak and they worked great for the last 3 years I owned. Also less money. If you plan on keeping the sled for significant time, go with the stainless.Got it apart... Has anyone tried the flange repair kits? With success?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I just replaced the right side pipe, as the left was fine. I think I got a stainless for 140 bucks or so. With copper donuts, it's the quietest it's ever been.
Yup. That is the updated ones with the deflector on the bottom side
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
Where did you find that for $140. Best I can find is $400 pair..
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
Hope you replaced both if you put copper donuts in there, other is sure to go, those ti pipes don't like the copper ones.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
They would be goin on the Wifes sled.. less than a 1000 mi. a year.
forebanger
- Mar 23, 2018
- northeast
- ATTAK
I just did mine. One flex pipe broke and all the graphite donuts were worn. Had existing ss y-pipes. Used new copper donuts. Within a day of the fix another flex pipe broke. Just decided to replace the remaining three original. That exhaust as cool as it sounds is a real pain.
stevieu1
Yup me too. As soon as I switched to copper donuts, the flex pipes started to leak so I just replaced all 4. $$$$$.I just did mine. One flex pipe broke and all the graphite donuts were worn. Had existing ss y-pipes. Used new copper donuts. Within a day of the fix another flex pipe broke. Just decided to replace the remaining three original. That exhaust as cool as it sounds is a real pain.
forebanger
- Mar 23, 2018
- northeast
- ATTAK
Replaced with 4 used from barn of parts. Had problems getting the recently replaced copper donuts back out. Guess you need to coat with anti sieze before you install. Well lesson learned. All back together as of yesterday and rode 130 miles no problems yet.Yup me too. As soon as I switched to copper donuts, the flex pipes started to leak so I just replaced all 4. $$$$$.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Hondaeasttoledo.com.Where did you find that for $140. Best I can find is $400 pair..
Wasn't in stock, either. Ordered new from Yamaha.
Might have lucked out...right side now 176 on ebay.
