06 mcx apex in tank fuel pump problem?
925rotax
kelowna b.c
06 apex 270 hp w no secoundary pump. the sled starts and then shuts off. I checked the power to the intank fuel pump. The pump has 12 v power at cranking and when the engine fires. The 12 volt power is lost and the sled dies? Anyone know where the fuel pump harness gets its power from. Its a buddies sled and we are hoping to get out tmrw
Are you getting any codes? If no oil pressure then the fuel pump turns off.
How long is "as soon as"? a second or two, or the engine doesn't even have a chance to make a revolution after you release the key from start position?
Can you just cycle the key a few times and hear the pump run the few moments each time during it's prime cycle?
while cranking there is 12v at pump. When it imediatly fires it runs 1-2 secounds and dies, runs out of fuel.When the sled fires and runs the 1-2 secounds. There is no power to the pump during the engine running ,only at cranking? I can hear the pump while cranking.
I got home and turned my ignition to on and you can hear the system prime. My sled 06 mcx apex 310 w secoundary pump. His sled does not make the initial prime noise. I can hear the pump on his when i add a 12 v seperate source to pump and ground. It doesnt prime the system like mine [noise sound ].
Try swapping the fuel pump relay, I think it's one of the ones in the left foot well.
thanks mbarryracing for your time! buddy had pulled out his powerblock. the one that the accessory 12v boosting lead goes to w a 40 amp and 2 10 amp fuses. he cleaned it because of corrosion andPUT IT BACK IN BACKWARDS. gold to negative. Thanks again!!
