07 apex exhaust temp. gauge
fortynine
colebrook n.h.
anyone using an exhaust temp ga.? what numbers should you get if probe is near donut at wye pipe. would adding baffles in the single pipe between the muffler & the wye cause too much back pressure & increase egt. ?
Not many are running an EGT, they are not the best system to monitor the AFR ratios in a 4stroke.
I would suggest you get a WBO2 wide band O2 sensor & AFR air-fuel-ratio meter. It will monitor your true AFR values in realtime. Basically it contains of a sensor installed in the exhaust tube, a gauge to display and control the computer where the sensor and gauge are connected.
If you're going turbo or SC later on a WBO2 system and a boost meter are mandatory.
