caraita
- Feb 5, 2015
- 2007 apex gt.
I started up my 07 Apex Gt for the season ran it around the yard and then it stalled. I started it again but all it does is just idle. Any Ideas? As soon as i rev it. it will just stall. I was thinking water in the gas? It has 725 miles on it and i have owned it since new. Thanks
TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
If it has last years gas in it , you are lucky it even started. Fresh gas may make a world of difference.
Try to pump out the tank first.
725mi !! WOW . does it still have the stock battery ? have you checked to see if rodents chewed on things? maybe its mad at ya cause ya dont use it
caraita
- Feb 5, 2015
- 2007 apex gt.
No stock battery I had to change that last year. and yes it was my garage ornament.725mi !! WOW . does it still have the stock battery ? have you checked to see if rodents chewed on things? maybe its mad at ya cause ya dont use it![]()
DTR 82-27
- Dec 22, 2006
- Drumbo, ON
- 2018 SIDEWINDER S-TX DX 137
You may want to add some Seafoam to the new gas as well. It will help get rid of any moisture and varnish left by the old gas.
- 70K
- 40K
