07 Phazer Cold Start/Fuel Pump
longlostsks
I picked up a 2007 Phazer Mountain Lite with about 1,500 miles. Started and ran fine first day. Second day, outside temp was -15F. Sled started up fine, we went for a 15 mile ride. Went to start the sled an hour later, and would not start. Motor turned over, but the fuel pump did not sound like it was kicking in. Brought sled into garage, and after it warmed up, fuel pump kicked in and sled started. Rode again, shut it down and after an hour, same thing happened again.
New to Yami and 4 strokes. Is this a recurring issue and is there a fix?
There is a update for the starting problem on the 07s!
Had it done to my daughters two Phazer GTs & they're perfect now!
See your nearest dealer for details!
BR
BR
This is a Nytro. The Bulletin re. the Phazer Cold Start does not apply. Neither did the conditions of the post.
  • 07 Phazer Cold Start bulletiin.pdf
