subysti04
This just seemed to get real bad on my wife's phazer. I lifted it off the ground and its still real hard to turn. Is there a grease fitting somewhere for the steering I missed? Why would it get hard to steer all of a sudden?
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Assuming its not due to physical damage, the upper steering block is just plastic and may be worn out. I upgraded to the OFT steering block and it not only eliminated the sloppiness in the steering shaft but also smoothed out the steering.
Has the Snow intrusion recall been done? This helps prevent Icing in the steering rack area.
pat the rat
I have the same issue when i go play in powder,ice forms in the steering linkage and becomes very hard to steer,check to see if your rubber boots are not torn,mine are
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
lube the tie rods at the boot - both of mine did this - other than that you may have to strip the plastic to make sure the bracket at the first joint is still tight to the frame.
subysti04
Recall is done and the boots look good. That's why I thinking I missed a grease point or something. Woolyviper did you just spray in behind the boots?
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
there are also bearings on the stem on top and bottom. The ones on my phazer with 4K were pretty tough but I bought a new subframe and the bearings are in much better shape. maybe pull the stem and pack some grease down there?
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
cannondale27 said:Has the Snow intrusion recall been done? This helps prevent Icing in the steering rack area.
anyone have pics of what this entails? This is an expired recall, so it cant be done retro-actively. Mine was never done. Curious if its something I can engineer myself?
Also you might have had the tierods come lose and turn so that they bind.. Happened to med after i hit a tree stump
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
Thanks!!!
am I reading that right? it was just that plastic cover and those 'ears' on the side of the airbox?
Yes pretty much.Probably more important is the filterclip mod.Saw some blown engines from ingesting those clips.
- 7K
- 9K
