snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I have someone with a 2007 phazer that has a no start. sled has compression, spark and fuel pump is working. they have no power to the wires that plug into the injectors. any ideas as to what it could be? any help would be great. Thanks
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Along with the fuses, check the relays, especially the one for the fuel injection. Relay might be bad (seems to be popular these days). Check out the schematics in the manual and follow the leads.
greg9705
- Mar 19, 2007
I am having the same problem as you snopro442. Did you ever figure out the issue? I know this is a old thread.
Thanks Greg
Thanks Greg
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
It helps to put an @ in front of the user name you're trying to get an answer, like this:
So @snopro442 , ever get this figured out?
The user gets a notification they were mentioned in this thread.
greg9705
- Mar 19, 2007
Thanks, I was not aware of that.It helps to put an @ in front of the user name you're trying to get an answer, like this:
Cool! Never knew that.It helps to put an @ in front of the user name you're trying to get an answer, like this:
snopro442
- Dec 10, 2007
- neenah wi.
Boy that was awhile back and to be honest I cannot recall what the problem turned out to be, sorry I cant be any help.
greg9705
- Mar 19, 2007
Thanks @snopro442. I did figure mine out finally, it was a broken wire at the injector wire harness plug.Boy that was awhile back and to be honest I cannot recall what the problem turned out to be, sorry I cant be any help.
