08 Apex not charging
rat4020
Cold Spring Minnesota
Polaris and Turboed Apex in a off road buggy
My 08 apex quit charging I drove back to my shop did a volt test it was below twelve volts and the pink wire was like rely hot. And I had a good rectifier from a apex doner sled. I installed it and started it, checked voltage was like 13.7 life was good for about a half hr max then the low voltage message came across the cluster again. I guess my question is could my stator be going bad and frying the rectifier. I did an ohm test on the stator and it had the same results as a doner stator I also tested which had the same Ohm readings within specs.
Did you check for any shorts to ground on the stator? It should be infinite or OL. Also check the AC voltage coming out of the stator on each leg. Each should be like 42V AC and even across each leg.
