dylanjen9
Last week the stator went out was replaced with oem
On next ride it had problems starting and one of the relays was making a clicking noise with key on
After changing relays it would start but not idle and die when let of gas
Replaced throttle position sensor does the same thing
It runs good and idles for the first couple minutes then starts acting up
What could be the problem? Also 8200 miles
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
No codes? Which relay? That could be due to a battery low voltage, check battery. Check the gap on the crank sensor, if this just started after stator replacement.
As Tbay said, check the gap of the crank sensor. As the motor heats up the gap does change and if you are on the outer limits of spec you may encounter a problem.
I would also check the ground blocks for corrosion.
dylanjen9
No codes and I think it was the third relay from outside. would the crank sensor be the problem even if it runs good at trail speed
dylanjen9
Also what is the proper crank sensor gap?
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Not sure what the proper gap is, had to have mine changed at a dealership when I was on a bagger trip in Quebec. You had it replaced with a OEM so the gap should be right. Grasping at straws. Someone who has done this could probably chime in. How many blades on the relay. Load relay 4 wires R,Br,W,Br/l . Fuel Ing(pump) relay 4 wires R/L,R/G,L/R,R/W. Fan relay 4 wires Br/g,R/W,L,G/Y. Headlight relay 5 wires Y,L/W,G,Lg,B.
COLOR CODE
B . . . . . . Black
Br . . . . . Brown
Ch . . . . . Chocolate
G. . . . . . Green
Gy . . . . . Gray
L . . . . . . Blue
Lg . . . . . Light green
O. . . . . . Orange
P . . . . . . Pink
R . . . . . . Red
W . . . . . White
Y . . . . . . Yellow
B/L . . . . Black/Blue
B/R . . . . Black/Red
B/Y . . . . Black/Yellow
Br/G . . . Brown/Green
Br/L. . . . Brown/Blue
Br/W. . . Brown/White
Br/Y . . . Brown/Yellow
G/B. . . . Green/Black
G/R. . . . Green/Red
G/W . . . Green/White
G/Y. . . . Green/Yellow
Gy/R. . . Gray/Red
L/B . . . . Blue/Black
L/R . . . . Blue/Red
L/W. . . . Blue/White
L/Y . . . . Blue/Yellow
Lg/B . . . Light green/Black
Lg/W. . . Light green/White
O/B. . . . Orange/Black
O/G. . . . Orange/Green
O/L . . . . Orange/Blue
O/R. . . . Orange/Red
O/W . . . Orange/White
P/W . . . Pink/White
R/B . . . . Red/Black
R/G. . . . Red/Green
R/L . . . . Red/Blue
R/W . . . Red/White
R/Y . . . . Red/Yellow
W/B . . . White/Black
Y/G. . . . Yellow/Green
Y/L . . . . Yellow/Blue
COLOR CODE
B . . . . . . Black
Br . . . . . Brown
G. . . . . . Green
Gy . . . . . Gray
L . . . . . . Blue
O. . . . . . Orange
P . . . . . . Pink
R . . . . . . Red
W . . . . . White
Gy/R. . . Gray/Red
R/W . . . Red/White
