If you pull your front strap up it should imrove the track attack angle. Will also add a fair bit more ski pressure though. I can't help you on the rear as I don't have that at all. In theory I would think for powder you'd want it all the way out so the angle is better but not having it and seeing it I can't say for sure.. Didn't know that they used a set up like that though..
sorenson1610 your right tighting the strap will add more pressure to the skis and will reduce ski lift. When i had my ripsaw track on my front and rear limiter strap were set at the 3rd hole so the approach angle was less which seemed like i was not trenching as bad.
When i installed the intense track i let the rear limiter strap all the way out and the front strap is in the second hole. I was in some deep snow and i was trenhing like crazy. The ripsaw was performing better in the POW than the intense.
Just want to hear other peopls input on limiter strap adjustments to there rtx.
