Shawano ZR
- Jan 16, 2021
- Shawano, Wisconsin
- 2016 ZR7000
I have a 2017 tuned Sidewinder and am looking to put a 10 tooth front drive sprocket on it. Does anyone know where I can buy these? I would really like to get an intro/extrovert drive version as my sled keeps spitting clips off the track. TIA.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
What pitch ?
Shawano ZR
- Jan 16, 2021
- 2016 ZR7000
2.86
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
10 tooth 2.86 is a huge driver but available . Hurricane either will have them or can get them
Shawano ZR
- Jan 16, 2021
- 2016 ZR7000
Thank you
Never Satisfied
- Oct 10, 2017
- Madison
I'm not sure you'll have much clearance. We run 9 tooth 3.0 drivers on my 174 Hypersports Promod and you have to be careful. A 10 tooth 2.86 will be 1.86" bigger.
I've also never spit clips of anything, there are bigger issues going on.
Kingersrx
- Dec 29, 2018
- Blind river
- 2019 srx
I put a 2.86 10 tooth avid intro, extro on mine. I would not recommend it, no clearence and had to modify front of rails to not hit driver
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
IT can done, but yeah not much clearance
Turboflash
- Mar 18, 2019
- Southern MN
Is it stock?I have a 2017 tuned Sidewinder and am looking to put a 10 tooth front drive sprocket on it. Does anyone know where I can buy these? I would really like to get an intro/extrovert drive version as my sled keeps spitting clips off the track. TIA.
I've never seen anyone post about an issue like this here on TY. This chassis/engine configuration was born in 2017. You'd think if this was going to be a problem, we should have heard about it by now? How far out are your limiter straps? Arctic Cat had a warning in the service manual to NOT lengthen limiter straps. Are the rounded plastic rail ends good and in place? Did someone re-clip the track and not do a good job? Is rail mounted in the correct holes? Should be the rear-most hole in front. Something is amiss if it's spitting out clips.
Shawano ZR
- Jan 16, 2021
- 2016 ZR7000
The chassis is stock, limiter straps have not been lengthened, track was not re-clipped as far as I can tell. Motor is not stock, running about 290hp.
Shawano ZR
- Jan 16, 2021
- 2016 ZR7000
Thanks. I think I'm going to not do it.I put a 2.86 10 tooth avid intro, extro on mine. I would not recommend it, no clearence and had to modify front of rails to not hit driver
Turboflash
- Mar 18, 2019
- Southern MN
I'd continue to investigate. I'm running 315 HP and have never spit a clip. Same for 2 of my friends.
traps have not been lengthened. Are they set at stock length? Are clips worn out, ie super thin due to wear?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
315 on pump gas ?I'd continue to investigate. I'm running 315 HP and have never spit a clip. Same for 2 of my friends.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Hurricane is offering 310 on pump gas now
Shawano ZR
- Jan 16, 2021
- 2016 ZR7000
I'll have to examine the clips more thoroughly when I drag it out of the trailer this weekend. Was going to get a clip tool and re-clip missing ones. Does anyone have a recommendation on which clip tool / clips to buy? I really want a decent one as this whole thing started when a clip came loose on the first day of my last trip last season and took out that damn-hard-to-get-at short coolant hose that connects the cooler in the tunnel. Spent 5 hours in the trailer fixing it while everyone else was riding.
