YamahaPhazer
- Sep 24, 2011
closed
On a 2010 I would probably do in this order.
-OFT relocator and Roll over valve
These items are fairly cheap and 95 percent of people that have them will say they are must haves
-Track
Cat take off's can be great cost effective options. But if Boost is in your future the money would probably be better spent on a CE 2.5 or a Accent.
-Concept front end
At this point you have got a good riding sled.
Then I would go Boost or Skid. both will make a big difference. If you have boost in the future I would not waist your time with other performance items. I could not be happyer with my boost and I rode my sled for 2 years without it. It just rocks in every situation.
-Track
-Concept front end
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I would do;
OFT relocator and ROV
Roest skid plate
Track
AirFrames
Skid- Poo 155 or Timber.
BOOST
Roest skid plate
Track
AirFrames
BOOST
hugger70mtnmax
Relocator and Roll over valve first for sure.
I would do the skid plate and air frames next.
YamahaPhazer
- Sep 24, 2011
what are roll over valve? and if i change them what is it gonna change? thx
Dimebag
Its a tether with a valve that close the vent hose to prevent oil leaking out of your engine when you roll it over, and a must have to avoid engine damage.
Check out www.oftracing.com tomorrow, i believe they will continue taking orders by then.
YamahaPhazer
- Sep 24, 2011
Dimebag said:Its a tether with a valve that close the vent hose to prevent oil leaking out of your engine when you roll it over, and a must have to avoid engine damage.
thx
big_red1a
You will need the stock header for MC-Xpress or other rear mount turbos I agree dont wast money on other mods just save for the turbo
YamahaPhazer
- Sep 24, 2011
ok, so it is better to keep my stock exhaust and header? because maybe in the futur i want to have a turbo on . and what about air filter?big_red1a said:You will need the stock header for MC-Xpress or other rear mount turbos I agree dont wast money on other mods just save for the turbo
big_red1a
Should not need air box turbo will use intercooler or plenum in its place.
