TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
09 Nytro XTX with a 2860
I'm currently running Ulmer 60g super tips
8 lbs set up
Heal= 1 tungsten and 1 washer
Mid= empty
Tip= 2 washers
Rider weight 220
WOT rpms @ 9000
Where should I add and how much weight for a 10 lb boost set up with rpms around 8900.
Much appreciated!!
Kevin
8 lbs set up
Mid= empty
Tip= 2 washers
Rider weight 220
WOT rpms @ 9000
Much appreciated!!
Kevin
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Anyone? I just want to make sure I'm adding weight in the proper locations.
ShootToThrill
Yours seems light to me. My 5psi kit runs good with 3washers in tip, 3 in the mid and 2 tungsten inner. But you prolly have different springs etc... Ulmer has tons of experience with the super tips, a call to him would be worth it. Maybe add 2g tip, 2g mid, 2g heel run it and adjust from there?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
cwcsrx700 said:Yours seems light to me. My 5psi kit runs good with 3washers in tip, 3 in the mid and 2 tungsten inner. But you prolly have different springs etc... Ulmer has tons of experience with the super tips, a call to him would be worth it. Maybe add 2g tip, 2g mid, 2g heel run it and adjust from there?
He has 60 gram base weights and you have 50 gram base weights, that's the reason for the difference in washers, etc.
Kevin, I sent you an email this morning with recommended changes. I was gone from Friday until this morning and didn't get to check my emails until then.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Srxspec said:cwcsrx700 said:Yours seems light to me. My 5psi kit runs good with 3washers in tip, 3 in the mid and 2 tungsten inner. But you prolly have different springs etc... Ulmer has tons of experience with the super tips, a call to him would be worth it. Maybe add 2g tip, 2g mid, 2g heel run it and adjust from there?
He has 60 gram base weights and you have 50 gram base weights, that's the reason for the difference in washers, etc.![]()
Kevin, I sent you an email this morning with recommended changes. I was gone from Friday until this morning and didn't get to check my emails until then.![]()
Recevied your email. Thanks Allen, will use your suggestions as a starting point. Much appreciated..
Kevin
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
load them around 75-77 grams loaded from bottom no weight on tip.
try this.
How many hp nytro have a 8#?
try this.
