12 volt adapter no juice?
flmcut1
western ny
mod electric shield plug to plug into 12 volt adaptor, no juice at end of plug. when plugged into car lighter got 14 volt ,any suggestions beside fuses going check them tomorrow ty
rx1ton said:
I just checked and it is plugged in...
Wire loose? You may have to trace it to find the bad connection. There is a plug end behind the right foot well. This should be constant power. Maybe, you can use that for the time being?
1CS
Is your plug compatible? I read somewhere that Yamaha has thier own plug design and you have to buy it from the dealer. You can check to see if you have voltage with a meter at the connector or even in the harness. I have not tried it yet since I ran my own fused wires and connectors from the battery. :4STroke:
flyingpig said:
I"ve tried mine with my garmin and it worked fine!
My Garmin works fine also. But a couple of days ago I plugged in a 12v air compressor to fill a small tire.....No juice. I think it has something to do with the plug style?
flyingpig said:
I"ve tried mine with my garmin and it worked fine![/quoteHey pig i pluged in my garmin etrex legend with its own garmin 12 volt cig. plug that attaches to the top of the gps and turned it on,but how do i know its not just the batteries power that is powering it.] ;)!
rx1ton said:
tmk..where is the fuse?
I don't know which one it is exactly - look in your owner's manual towards the end it shows how to get to the fuses.
