121" with boost
sheetwright
Northwoods USA
2021 Yamaha SRX
How many studs are you guys running on your tracks if you have a shorty? I will be running about 10lb's of boost on my Nytro. Was thinking about 192 studs instead of the 144 I have now. Should I go more then 192? This will be a hopped up trail sled. Some people were saying to add an extension on and go 136 instead. One project at a time is the way I will go with this one.
You running a turbo you might be ok, but on my Super i am long tracking it....
Skydog
kinger said:
Actually I have 240 studs, wow
I dont think a 136 is needed if you ease into the throttle hit 30 mph and peg it!
So are you running a turbo or a charger on your 121"? What length are your studs? Also if I switch to a 136" any paticular 1.25" track, or stick with the original style?
A 121" is too short of a track IMO, too scary dooing wheelies all day long at speeds past 100 MPH or 160 KMH. I would recommend stretching it to at least a 136", is will also run straighter that way.
HAHAH May be your sled not mine!! HAHA I WISH!! :) :)
A shorty with 300+ HP will when hitting a bump in the trail at WOT, kinda scary don't you think.
Ulmer or Hauk both said to put the sled at 9-10lbs which will make the sled about 250HP for the trail :-o Thinking about the length? Want some control and trail turning ability?? If there is such a thing?
I put a 128" 1.375 on my RTX and I like that track its a cobra, little stiffer than the ripsaw, and 255 1.5's
