Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
[/quote] these sleds will never get carboned up to the point they will loose eficiency and h.p.[/quote]
Apparently you never had an oil burning 03 that had carboned up rings.
Phazed-Coug
LOL, what is it? a Potentiometer (Variable Resistor) installed
in the Air Temp sensor, that messes with the fuel mixture
to make the engine think its colder? yeah they are all over ebay, you can make them for 15$ or less with radio shack parts
and hurt your engine in the long run?
Tork
Phazed-Coug said:LOL, what is it? a Potentiometer (Variable Resistor) installed
No in this case it wont be that, overall the EFI sleds run plenty rich.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I missed the part where it said this only helps carboned engines. They don't seem to indicate that 2 strokes WONT benefit so that would a contradiction tho.snappy said:after reading those articles if this product is a hydrogen generator i dont see how can increase h.p. on an engine that is new and not carboned up.and at the rpm's these things rev at and with the fuel injection these sleds will never get carboned up to the point they will loose eficiency and h.p.actionjack said:Tork said:Enough clues that I may know what it is!!!!!!!!!!
You nay sayers and bashers may have to eat your words.
It may be an onboard hydrogen generator, that adds a small amount of hydrogen to the air fuel mix.
This device does work guys, more HP and more MPG
http://www.savefuel.ca/oxy-hydrogen/
http://web.mit.edu/newsoffice/2003/plasmatron.html
Looking over those links you may be right. If you're not, maybe someone should start adapting the OXY-HY for 4 stroke sleds anyway.
danq
Wow the theories are "way" out there. I'm guessing it is something like a power commander dyno tuned for the Apex....
http://www.powercommander.com/
What to I win?
What to I win?
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
HAHA, it's a 5 lb hunk of FITCH FUEL STABILZER!!!!!!
Apparently you never had an oil burning 03 that had carboned up rings.[/quote]actually i just sold my 03 rx1 that used a quart of oil every 500-1000 miles and i rode it for over 10,000 miles and it never got carboned up to the point it lost power or effiency.
DoktorC
The increased compression from the carbon on the pistons made up for the lost compression due to the leaky rings.
Carbon Rocks.........
yammiman
GUYS! - I think I figured it out! - its a Flux Capasitor! - $559 is for a weekend worth of Plutonium! - and we all thought it was something more complicated! - McFly! - McFly!
Yamahnator
Your snowmobile will now run on rotten banana's, walmart bags and other garbage...
Seriously though, be skeptical but give him the benefit of the doubt for a little longer.
actionjack
- Apr 9, 2005
I miss this thread. What's new with the patent application?
welterracer
I contacted that company about the usage of that product on a snowmoible.. HERE is there reply...
Re: Ticket 695, Responded
Dear Brian Welter
A new message has been added to the service request #695.
Yes, it would work on a snowmobile.The only thing you need to watch is the amperage. For a snow mobile it should be around 5 amps.
Regards,
Andreea
Dear Brian Welter
Regards,
Andreea
welterracer
My question is this... How do you keep the water from freezing?
Iceman57
The water is mixed with an electrolyte to enable separation of the hydrogen. The mixture forms a gel like substance and will not freeze.
alaskanbowtie
How Long will it be ?
So how long be fore this miracle device can be revealed or will this post dwendle away with others of the like........I'm still interested ?
