DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
Thanks Lb i tyhought so
So do i really need a stiffer bar?I do think so
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
welterracer said:Well just got back from the TY ride in Houghton..
Anyways..
Before i went up there i installed a 13mm swaybar from pioneer performance and removed the lower 10mm transfer rod washers and replaced them with 5mm washers (supposed to reduce decelleration weight transfer) and i aligned my skis so they were only .50 out! and loosened the front springs by 4 turns each side!
Brian![]()
Hey Brian, What is your fully extended spring length after you adjusted them?
vtrxrider
Bob, Forgive me if the washer question got answered. They are talking about the rear skid transfer rods just in front of rearmost wheels. They both have a 14mm bolt and a white nylon washer. If you change the thickness of those washers it will benifit your transfer. Happy new year, Gordon
When I had my 03 RX-1 I changed the sway to a 12mm & added longer links. The change in handling was remarkable & there was no deterioration in ride quality - even in the uneven stutter bumps. With this experience I had the dealer put the 13mm sway on my 05 RX-1, & I'm glad I did!! My early impression is that it rides better & handles better than my son's Rage!
LICKETY SPLIT
I cannot find the phone # for pioneer performance any have it? thanks.
Bob Miller
- Apr 19, 2003
- New Milford CT
LICKETY SPLIT said:I cannot find the phone # for pioneer performance any have it? thanks.
Pioneer Motorsport
Manufacturers links. For Pioneer Performance please click here. or on the link at the left side of this page. 12220 OLEAN ROAD - CHAFFEE, NY 14030. phone 716-496-6000 fax 716-496-7565 ... Pioneer Motorsport is Western New York's finest recreation dealer, featuring vehicles from 6 different manufactures ...
www.pioneermotorsport.com
It looks like you can't runa 13mm in the 2003 is that right?
you would have to get different links and bushings from the looks of it.
