For you guys that installed the 13MM sway bar would appreciate your feed back as to handling characteristics versus how it affected the ride on the APEX GT.
Tork
A really nice write up by Welterracer is in the FAQ section
http://www.ty4stroke.com/viewtopic.php?t=23441
welterracer
I love my 13mm swaybar.. I think the 12 mm bar would be better for someone less aggressive..
Either are better than stock
13mm swaybar
Installed the 13mm, made for a very aggressive feel (and harsh). Dropped down to 12mm, achieved better ride but still flat cornering. It's going to be rider preference. Personally, I'm going to have my shocks recalibrated and probably go back to the stock bar.
Q: Did you ever see a snowcross racer use a sway bar????
welterracer
snocrossers dont go threw corners at over 50mph..
They basically drag race threw the bumps and jumps and lock up the brakes.. Come to a stop...TURN.... and drag race to the other end again..
You will also notice that snocross racers use C@Apro race skis.. which are very aggressive.. (did you ever notice how hard they have to fight to turn there sleds when in a corner.?)
leaddog
13mm is good for me. Body roll is much more under control now.
zipclean
2006 Attak,13mm made a positive diff to control the body roll and skis kicking. BETTER then stock.
markusvt
- Mar 5, 2005
I like it.
http://www.ty4stroke.com/viewtopic.php?p=243150#243150
APEX GT 4 STROKER said:For you guys that installed the 13MM sway bar would appreciate your feed back as to handling characteristics versus how it affected the ride on the APEX GT.
DANX123
WHERE TO GET A SWAY BAR KIT. ANY INFO WOULD BE APPRECIATEDAPEX GT 4 STROKER said:For you guys that installed the 13MM sway bar would appreciate your feed back as to handling characteristics versus how it affected the ride on the APEX GT.
Pioneer Performance
welterracer
This might help a little more www.pioneerperformance.net
so a stock bar is 11mm and you have the choice of 12 and 13mm, correct??
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I rode an Attak with one and didn't like the vibration that was transfered to the handlebars. I believe Dirk Diggler shared my dislike for it. We both had tingling hands after riding with it. Not for me................
welterracer
Yes you are corect MR.SLED!
If you want to get rid of the ski lift the 13mm bar is the only way to go..
THe 12mm might be a better choice for people like Might and Dirk.. (people worried about excess vibration and transfer threw bars)
- 10K
