Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Yamaha GYTR front shocks
You have a pile of track on the ground now. Pull up the limiter straps on the center shock 1 or 2 holes or you can soften the center spring and let the rear skid sit in more. If you running the stock skis, more aggressive skis will also help.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
I'll try that, thanks a lot for the help. I'm currently on the stock skiis also so that's kinda a problem I would assume.
If you don't want to get new skis try some aggressive carbide. Shapers always worked well for me.
Try some slim jim dual carbide runners. I also added MTX ski's which have a much deeper keel.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yes, I stretched my Phazer with a 144" track and I am running the setup that Mr Sled mentions above. I loosened up the front skid shock or center shock spring until it is loose, pulled in the limiter strap a couple holes and lowered the front end by running low PSI in my Floats. My Phazer with the 144" track and no studs corners like its on rails. G.B.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
2X.Try some slim jim dual carbide runners. I also added MTX ski's which have a much deeper keel.
I run MTX skis on mine and didn't have to change anything in the skid.
Which model did you start with? I stretched a GT skid and I know they have softer springs than the FX.
