Jgarr503
- Feb 23, 2025
- Sidewinder
Any solutions for this sidewinder no start ?
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
I just went through this on Friday, had to give the sled a little bit of throttle for it to fire and stay running, it warmed up a little bit and tried it again on Saturday and everything returned to normal, didn't have to hold throttle open, weird stuff man.
Turboflash
- Mar 18, 2019
- Southern MN
Ice/condensation/frost?I just went through this on Friday, had to give the sled a little bit of throttle for it to fire and stay running, it warmed up a little bit and tried it again on Saturday and everything returned to normal, didn't have to hold throttle open, weird stuff man.
Frozen fuel pump relay?
Frozen/frosted up solenoids?
Moisture/water in BOV vent hose?
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
IDK it was in storage, in the trailer, not like its been being ridden out in the elements. It acted like the idle was set too low. Crank crank crank nothing, but as soon as i held the throttle open a bit it fired right up, but i had to hold it at 1500-1800Rpm or it would die. It was cold, sub zero earlier in the week and only a high of 20 that day plus it was inside the ice box trailer. i got busy and left it sit, tried again Saturday morning and it was perfect. so idk. fingers crossed headed to the U.P. a week from today, its going to be warmer so it should be fine
998
- Dec 21, 2024
- Big River
- sidewinder
Had same problem crank but would not start ended up being the pick up coil bad news is it come all one piece 780.00 $ stator and pick up coil cant buy them sepratly well hope it helps....
3 weeks ago, one of my customers had a no start with this problem. He was wanting to ride that day. He brought the machine over right away, I put a coil in I get from a place in Stratford and he was running by lunchtime.
