Rx1M5
Can I use a 70 link chain for 19 40 gears or do I need a 68?
Thatspec
I believe anything lower than 20/40 would require the 68. Thats getting pretty low, are you also using a 3.0 pitch track with 7 tooth drivers?
Not to highjack your thread but along the same lines would 7 tooth 3.0 pitch drivers be lower gearing than 8 tooth 2.52 pitch?
MT
MT
Trxster
I have been riding 20/42 which is the same 2.1 ratio but I am using stock 8 tooth drivers 2.5 pitch. I would say it is great for most everything but especially good for deep snow and trees. Not great if your racing on trails.
Rt
Rt
Thatspec
I wish I knew what my gearing was but suspect it is too high. Not about to break open the chaincase to find out. It does have 8 tooth 2.5p extroverts (I guess 8 is stock anyway) but will still hit 100 on the way up to the real snow. The original owner put a reverse kit on (changes forward gearing as well) but Hartman tells me there were two kits available with one geared more for east coast use (more like 22/38 ). Gears 'aint cheap not to mention the pita. Says this is likely why I have blown up two belts recently while boondocking/climbing.
Did a little searching but still can't find the definitive minimum for the switchover to a 68 link, sorry.
Damned if it isn't raining again here at 4000' in Oregon.
MT
MT
Trxster
Thrusted Vector
The mountain RX stock is 21 40,reverse or not.The Apex is running 20 40
Rx1M5
I am going to try 19 40 with my 8 tooth 3.0 pitch drivers= 9 tooth 2.52. Currently I am running 19 42 which is pretty good all around.
I picked up a reverse for the sled which has a 40 tooth bottom so if I don't like this I can go 18 top or get the mpi 42 bottom for reverse. I was just wondering if I needed to order a new chain.
Thrusted Vector
Yup,a 68 tooth will be in order if you go with with 19 40
Thatspec
Any reason you can't use whatever size bottom (or top for that matter) gear you want with a reverse kit, or are they special with the reverse kit. This link;
http://www.yamahasportsplaza.com/pages/ ... fault.aspx
shows the kit being sold with either an 18/38, or 18/39, both pretty low gearing. I'd be happy if I had either of these but suspect not with the top end trail speeds I'm getting.
RX1M5, you say you have a 40 tooth compatible with reverse?
Thanks, Mark
Thanks, Mark
Thatspec
I guess that link doesn't take you straight there. Have to plug in the '03 RX1 MT and click on reverse kit....
Thrusted Vector
40 tooth comes stock on the mtn reverse kit
Rx1M5
Yep thats correct
Thatspec
Here is/was one for sale with a 21/39 though perhaps this would not work on a MT;
http://www.ty4stroke.com/viewtopic.php? ... everse+kit
Appears either these kits were sold with a variety of gearing and /or.... any forward gears can be used???
Still curious, Any reason you can't use whatever size bottom (or top for that matter) gear you want with a mountain reverse kit, or are the forward gears specially made for the reverse kit only in certain sizes?
Thanks, Mark
Thanks, Mark
Thrusted Vector
I f you get the kit cheap enough,you can swap out the 39 for a 40 easy enough or just the top gear to 20,however the difference between the 39-40 is fairly minimal.
