SAWEEEEET!
Keep tracked of the wt. if you could.
you will probably have a 4 holer in your hands at some point also I would guess.
I'm thinking if the same person/shop does the weigh in, same scale, same degree of assembly, then we can compare apples to apples so to speak.
THANKS
THANKS
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Vector motor weighed 116 lbs with carbs attached to the motor & oil filter on the motor (all other components removed).
AKrider
Looks like you finished the easy part. The next step is to turn the machine upside down, suspend it from the ceiling, fill the crankcase with oil, lift and hold it into place and assemble from underneath.
2-3 beer job tops.
2-3 beer job tops.
hlmrx1
AKrider said:Looks like you finished the easy part. The next step is to turn the machine upside down, suspend it from the ceiling, fill the crankcase with oil, lift and hold it into place and assemble from underneath.
2-3 beer job tops.
Don't give Jim any bright ideas now, he may just try this to prove a point or something.
hlmrx1 said:AKrider said:Looks like you finished the easy part. The next step is to turn the machine upside down, suspend it from the ceiling, fill the crankcase with oil, lift and hold it into place and assemble from underneath.
2-3 beer job tops.
Don't give Jim any bright ideas now, he may just try this to prove a point or something.![]()
I actually have something else in mind. I've done so many of these motors now that I think I could re-build one blinfolded. Guess whose motor we're going to find out on....!
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
lakercr said:hlmrx1 said:AKrider said:Looks like you finished the easy part. The next step is to turn the machine upside down, suspend it from the ceiling, fill the crankcase with oil, lift and hold it into place and assemble from underneath.
2-3 beer job tops.
You can do it blindfolded but can you do it with a beer in your hand as well lol
I don't want to know what Don used to hone those cylinders either thats just sick
