Oil change/flush.
Come on now be reasonable the amount of time it will be running is not going to be contaminating the oil. Your searching now bud!
LOL...Do what makes you feel happy
:4STroke:
Apexaholic said:
My 06 RTX has sat now for the summer, I did oil change last year before season, did 655 miles.USED Amsoil synthetic.
Now its sat without starting for the off season.
Should I use a engine flush additive, run the sled get it hot, then change the oil out?
Or just change the oil and filter?
I have Amsoil again to go in.
no need to flush your system again!!!! your Amsoil has a protectant init that will coat your engine walls and seal it up good for the entire time it is sitting! that is one of Amsoil's great properties! i'm not going to get into the changing it before or after but you definitely do not need to flush!
